Re: M locked up
Posted by Bob M on September 19, 2011 at 12:19:11 from (69.207.87.100):
In Reply to: M locked up posted by JohnDeereGreen on September 19, 2011 at 10:38:03:
Can almost guarantee the starter pinion has jammed in the flywheel ring gear. It is a very common problem on H and M tractors as the ring gears wear out.
Try rocking the tractor in 5th gear like Jim suggests. Or loosen the bolts holding the starter to the bell housing then pull back/wiggle the starter a bit. If you hear a clunk and the crankshaft now turns, retighten the starter and you'll be good to go - at least until the starter jams again.
The only permanent fix is to split the tractor and replace the ring gear.
