Posted by F-Dean on September 19, 2011 at 17:39:18 from (75.249.92.150):
In Reply to: M locked up posted by JohnDeereGreen on September 19, 2011 at 10:38:03:
Did you turn the gas off when you parked it?
Twice I have forgotten to turn off the gas when I parked my M. The gas over-powered the float in the carb and ran directly into the cyclinder. (I have since replaced the carb.) Being a liquid, it will not compress. The result is that the cyclinder under compression cannot move.
Solution: Remove the plugs; make sure the on/off switch is OFF; and turn it over with a hand crank. After a few turns you can use the starter but leave the on/off switch OFF to prevent any sparks. And NO SMOKING!
Let it set while you change the oil and filter -- you may have gas in the oil. After an hour or so, put the plugs in and try starting it.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
