Re: B414 Hydraulic/Hitch Issues
Posted by JohnWyrwas on September 19, 2011 at 18:03:38 from (96.63.15.215):
In Reply to: Re: B414 Hydraulic/Hitch Issues posted by JohnWyrwas on September 19, 2011 at 17:12:34:
Also Jim,am I correct in assuming it is not the main cylinder if it does not leak down with the shut off closed?
Thanks
John
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
