Re: Farmall 1958 560 diesel
Posted by Armand Tatro on September 19, 2011 at 18:36:58 from (98.227.26.140):
In Reply to: Farmall 1958 560 diesel posted by Bo Mack on September 19, 2011 at 12:24:58:
Check the rubber fuel line between the final filter and the injector pump. I have had them look good on the outside and be collapsed on the inside and not let fuel flow. When you bleed that hose at the injector pump it will flow fuel for a very short time but with the hose disconnected from the inj. pump for two or 3 min. the flow will dribble down to nothing and you will have to replace that hose. Armand
