Re: Brake-Actuating Assembly
Posted by Janicholson on September 19, 2011 at 19:08:56 from (96.24.99.126):
In Reply to: Brake-Actuating Assembly posted by 1952 Farmall Super M on September 19, 2011 at 18:37:22:
Ebay, Most salvage yards, or Bates Equipment in Indiana. Many others, shop. The key is to get the stack of the expander and disks to measure .040" to .050" less than the outer case to inner surface distance when the expander is fully relaxed (balls in the lowest depth)
This will require machining of the outer housing mount surface, and careful measurement with a caliper, not a ruler. The balls/ramps should be lubricated with a dry teflon (PTFE)based spray, the same for the splines. The pivot points of the links can stand a touch of the same material. TRI-Flow is one brand. A 200 grit cleanup of the friction surfaces also allows them to break in easily. Jim
