Re: 450 won't stay running
Posted by Janicholson on September 19, 2011 at 19:22:05 from (96.24.99.126):
In Reply to: 450 won't stay running posted by deerly parted on September 18, 2011 at 17:32:33:
Fuel supply issue most likely{ Three common places to check. Fitting into tank (hole at sediment connection)
Screen in the sediment bowl. The screen at the carb inlet fitting. The fuel must come out of the drain plug like a puppy taking a leak! Use a pan to check it for a minute or more to assure it flows continuously. Jim
