Re: Super A rear wheels
Posted by gregthedc on September 19, 2011 at 20:19:39 from (216.74.210.80):
In Reply to: Re: Super A rear wheels posted by gene bender on September 19, 2011 at 19:16:53:
The Cast wheel is on the left and the pressed steel is on the right. If I swap them the tread will run backwards. Tire shop wants $100 per wheel to swap the tires. I have a manual and thats how I figured out they were wrong then the other gentleman confirmed it. Sometime in the past the owner had them mounted wrong. Guess I need to get that corrected, just realized it tonight when I was trying to put on the wheel weights. Thanks for the comments
