Re: Farmall M winter project
Posted by DanD on September 19, 2011 at 22:17:57 from (156.144.250.237):
In Reply to: Farmall M winter project posted by Hoosierhog on September 19, 2011 at 17:46:01:
If it runs good, shifts good and the clutch is good, it's good deal... it could do everything you need done. Most M's came with a belly pump and one way hydraulics, which will run your disk. Seems like there are a lot of good M's out there with useable tires and hydraulics for cheap. Depending on the dia of the disk blades and what you are disking... the old tires might surprise you if they hold air and have fluid in them or weights. If the clutch is bad under load or the engine runs but is not healthy...and you can't do the work yourself... It's probably not a good deal. Even buying used tires and paying for a dismount, remount, tubes? and fluid transfer could set you back several hundred dollars. Good luck..
