Posted by Heat Houser on September 20, 2011 at 06:20:44 from (69.66.35.73):
In Reply to: 706 gas Spark plugs posted by MattSillinois on September 20, 2011 at 05:24:52:
It kinda depends on what you are going to use it for and how good the engine is. The higher the number i.e. Champion D21, the hotter the plug. A good engine and heavy pulling, the D21 will cause the fuel to preignite since the spark plug elements will still be glowing red hot. This plug will do well with a lot of idling or an engine that is starting to foul the plugs due to oil burn.
Good engine and plowing? D14 or D16. Compromise, D18. Heavy pulling and backfiring thru the carb? Too hot, drop a heat range or two.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
