farmall c with carter carb
Posted by FC on August 21, 2000 at 05:45:01 from (63.80.243.2):
my 1950 farmall c is apparently running too lean. will run fine if choke is about 1/3 to 1/2 way out. recently put new gaskets, etc. in carb, also gaskets between carb and intake and manifold gaskets have been replaced, cleaned screen in inlet and replaced in fuel bowl and am getting good flow to carb. screw on bottom front of carb (i assume to be high speed mixture) doesn't look to be correct, but tractor used to run with it fine. any suggestions? is there any where on net with a blow up of this carb? what is float setting spec?
Post A Followup
: Re: farmall c with carter carb
