Re: oil leaking from plug and soot from exhuast
Posted by Janicholson on September 20, 2011 at 09:19:35 from (199.17.6.160):
In Reply to: oil leaking from plug and soot from exhuast posted by Pat Connors on September 20, 2011 at 07:01:06:
Your tractor is (as Allan indicates) NORMAL.
The spark plug gasket is bad, or the plug is not torqued correctly, (put a tiny dab of silver Moly antisieze on the threads.) Oil is to be found inside the cylinder, condensed on the chamber walls (especially when the tractor is not run hard working and up to temp.) The same element is at work on the soot!
A cold tractor muffler condenses water, a cold tractor produces more unburned HC. The soot condenses int the water making a wattery black slobber that is propelled out the exhaust pipe.
Run it hard for an hour and it will go away.
It will come back every time the tractor is operated toodeling arouns and short run times.
Jim
