Re: Aftermarket Radiator
Posted by buckeyebrierhopper1 on September 20, 2011 at 19:21:45 from (65.27.225.98):
In Reply to: Aftermarket Radiator posted by Kevin W on September 20, 2011 at 10:14:31:
if you can sodder,an feel entergetic,you can get rad cores from a co Detroit radiator.com, i ordered one from them,very reasonable,225 dollars for a ub moline,+about 6hrs an bit of luck put new core in it an only 1 small leak easy to repare runs fine now stays very cool. e-mail open dan
