Re: Neutral Safety switch idea.
Posted by Wardner on September 20, 2011 at 20:27:36 from (4.154.233.83):
In Reply to: Neutral Safety switch idea. posted by Janicholson on September 20, 2011 at 19:03:40:
Seems to me if one pulls the belt pulley gearbox, a three position, spring-loaded, center-resting off-on-off switch with levers linked to, or bearing on, the ends of all the rails, could be installed.
Of course there are other ways using magnetic pick-up or maybe some optical sensor.
Personally, I would have to go to a Power Transmission or Automation Specialist dealer and let them shuffle through their thousands of catalogs. Or maybe it's as easy as a google search. It's also likely that such a switch might be found in an auto or truck salvage yard for handling AC controls or any number of functions in a modern vehicle. I dunno. My newest vehicle was built in 1998 and is a low optioned 1-ton Diesel.
Just dreaming, Jim, and I am not even an electronics geek. Not saying your's won't work but magnetic pickup sounds cool and there is no contact. All three rails would have to "make" before a signal could get to the starter solenoid's "S" terminal.
