Re: Update on Farmall C stuck clutch
Posted by Jimb2 on September 20, 2011 at 20:27:50 from (174.115.9.174):
In Reply to: Re: Update on Farmall C stuck clutch posted by CT8N on September 20, 2011 at 16:06:46:
Hi CT8N, to your defense, you are correct on a Farmall C pulling from the standard drawbar will not cause the front end to rear up enough to go over rear wards. Do not try this connected to a 2 or 3pt drawbar raised above the level of the standard drawbar. DO NOT try this with a Ferguson or Ford that uses the 3pt as the drawbar.
JimB
