Re: Re: Re: Re: '41 still smoky
Posted by Cory on August 21, 2000 at 09:16:22 from (216.17.30.1):
In Reply to: Re: Re: Re: '41 still smoky posted by The Red on August 21, 2000 at 09:04:42:
That's the one that I found was completely plugged. I carefully removed it and pushed the plug out with the proper diameter wire and soaked it in carb cleaner. The carb kit did not have a replacement so I put the old one back in. Can you order just that part? Perhaps in the process of unplugging it, I enlarged the opening?
Post A Followup
: Re: Re: Re: Re: Re: '41 still smoky
