Posted by Janicholson on September 21, 2011 at 15:35:03 from (96.24.99.126):
In Reply to: 2606 won't start posted by bc on September 21, 2011 at 12:25:43:
The first issue is to determine if the timing is off. With the plugs out so it is easy to turn, put a test light on the lead to the side of the distributor from the coil. Turn on the ignition and turn the engine (pushing it in high gear works) until the first timing mark (in forward rotation) is at the pointer. The timing should now just cause the light to light or flicker as the points break. If the light stays out, look at the rotor and see where it is pointing. If toward a terminal, good, if not there are issues with timing. Rotate the engine till it does come on. then look at the pointer, if it is off 20 degrees or so the timing gears may have issues. Jim and
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
