A little trick i learned with my C is to use 4 pieces of all-thread to bolt the engine to the clutch housing and keep everything straight. At this time you need a support under the clutch housing or torque tube. then with the rear brakes set and tires blocked you can carefully slide the motor forward on the front wheels a foot or so. NOW you can get at everything and it slides back together and everything lines up. This may need more support and blocking than what I stated here to ensure safety, but it is probably the easiest , cheapest and in my mind safest way to do it. Also this lets you replace the clutch disc if you want to.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
