Re: Stuck Clutch?
Posted by glennster on September 22, 2011 at 08:21:07 from (76.224.4.21):
In Reply to: Stuck Clutch? posted by Grumpydaniel on September 22, 2011 at 08:07:26:
i have an h that the clutch will stick if it sets a couple weeks. i block the pedal down when i park it so it doesnt happen. when it did stick, i would drag the tractor out of the barn, point the front end toward the field, plan an escape route and start the tractor in 4th gear. keep applying both brakes with the clutch depressed while the tractor is running to break the clutch loose. if you can hook it up to a plow or disk, you can pull the implement with the clutch down till it pops loose.
