Re: Stuck Clutch?
Posted by Janicholson on September 22, 2011 at 09:36:26 from (199.17.6.160):
In Reply to: Re: Stuck Clutch? posted by Grumpydaniel on September 22, 2011 at 08:25:22:
The only way to get to the FW is to remove the starter. The starter hole gives access to the Flywheel. Not much will happen unless there is stress on it. Using a hand crank with 200 pounds hanging on the handle, with the tractor in High gear and wheels blocked will do. Jim
