Re: Stuck Clutch?
Posted by JRSutton on September 22, 2011 at 11:12:56 from (75.130.109.233):
In Reply to: Re: Stuck Clutch? posted by Grumpydaniel on September 22, 2011 at 10:57:32:
If you've got a large open field, you can start it up in gear and hit the brakes a few times (with the clutch pressed in). That should do it.
Not a big fan of doing it this way unless you've got PLENTY of flat ground, and you're real comfortable behind the wheel.
Be sure your brake pedals are locked together, and keep the throttle way down to start.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
