Re: 400 rear outside wheel bearing
Posted by pete 23 on September 22, 2011 at 19:59:57 from (74.32.234.149):
In Reply to: 400 rear outside wheel bearing posted by Dean Hoodenpyl on September 22, 2011 at 19:28:54:
You can pull that bearing from the outside, but I never felt it was worth the time of fighting it. I drain, pull pto, take off cap screw, put a forcing screw and spacer between bull gears , turn axle with pipe wrench and push axle out. Then you can push bull gear out of the way and check that inner brg also which is the one that goes to heck most of the time anyway.
