The only "shimming" to be done to the MCV (steering) pump is the gasket between the MCV or spacer plate and the center section. there are two different thicknesses. The repair manual says to use the thinner one if you can determine that is what was on the tractor originally or else use the thicker one.
Whining is usually caused either by air entering the pump or a mismatch of gear tooth angle. When replacing the gear you need to make sure that you have the 25 degree pressure angle gear. 06 and early 56 series tractors used a 20° tooth that will fit but they will be noisy and running a mismatched set will ruin both gears.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
