Re: farmall 240
Posted by CNKS on September 23, 2011 at 17:40:52 from (216.144.104.128):
In Reply to: farmall 240 posted by Todd Heck on September 23, 2011 at 16:58:28:
The 240 replaced the 230, which was the last in the line that started with the C. It is a more modern tractor with better hydraulics, etc than the 230. A stuck engine is a stuck engine, costs about the same to fix regardless of the model in that series. Problem is you can't run it to see if there are other problems. The 240 is no better or worse than the competing tractors of other brands.
