1940 h charging
Posted by NC JEFF on September 24, 2011 at 05:24:32 from (50.55.241.70):
Very original tractor with orig wiring that looks good. 6 volt gen cutout relay and 6 v pos ground. sanded all connections motor tested gen good cut out good voltage on both sides of ammeter took light switch box apart and off of frame to sand for good ground. ammeter shows discharge when non running and turn on lights shows charging when running on high setting with needle two clicks below 10a voltmeter shows 6.6 at battery. when running and i remove battery neg cable from batt the tractor starts to die and the current will jump between the two and shock you like elec fence. does tractor have to have batt to run or what is going on? also what is the little flat piece on the bottom of the light switch that has shiny alum colored metal wrapped around it? do i need 7.2 to charge?
