Re: 400 rear outside wheel bearing
Posted by pete 23 on September 24, 2011 at 09:31:38 from (74.32.234.149):
In Reply to: 400 rear outside wheel bearing posted by Dean Hoodenpyl on September 22, 2011 at 19:28:54:
As you no doubt don't intend to do this often, just use the bolt holding bull gear on and find correct length spacer and put between it and other side bull gear. You may have to add some extra spacer as there won't be enough threads to push axle completely out of bearing. Hold bolt head with wrench and turn axle.
