Re: loose handle on hyrda touch
Posted by Wardner on September 24, 2011 at 10:07:34 from (4.154.237.17):
In Reply to: loose handle on hyrda touch posted by mike paulson on September 24, 2011 at 04:53:07:
The steel splined insert on the aluminum lever is hardened. The shaft coming out of the valve isn't as hard. It is probably worn. It can be easily replaced. Have to take off the oval cap on the valve body, drive out a small pin on the shaft, and the shaft comes out in two pieces. If that is replaced and it still wobbles, you will need a new aluminum lever.
Or you could try some epoxy in the splines to eliminate the wear. Might be worth a try but I don't see it as a long standing repair.
