Re: loose handle on hyrda touch
Posted by bkpigs on September 25, 2011 at 06:18:36 from (24.182.232.107):
In Reply to: loose handle on hyrda touch posted by mike paulson on September 24, 2011 at 04:53:07:
not sure what tractor you got but on my 300 i used a larger cotter pin. Where the shaft connects to the lever on the block there is a hole drilled through both pieces. Mine had worn out there so I replaced with a larger cotter pin, before that we had a 16d nail in there and it held it pretty tight.
