Re: c engine block
Posted by tractorsam on September 25, 2011 at 16:30:24 from (24.222.98.65):
In Reply to: c engine block posted by bowih on September 25, 2011 at 15:45:31:
A lot will depend on the casting numbers of the blocks. Look behind the oil filter on both blocks. If the 200 uses the number 354898R* (it doesn't matter what number is where the star is) then it uses sleeves that are 3 7/16" OD at the O-ring seal. Unless your C uses the same casting number block it is highly likely that your sleeves will be the smaller 3 5/16" OD. Hope that made sense. Sam
