Re: Hyd prob on M
Posted by Janicholson on September 25, 2011 at 16:39:48 from (67.72.98.45):
In Reply to: Hyd prob on M posted by F150Mustang on September 25, 2011 at 12:41:06:
We need a bit more info. What system does the M have? Belly Pump, or Live, Remote control with 2 hoses, or one. If one hose, the coupler is probably stuck, and will need the pressure taken off (jack up the plow to relieve the cylinder). Be careful, if the coupler is broken it can be dangerous if all pressure is not removed first. Jim
