Re: Maximum Towing Capability
Posted by F150Mustang on September 25, 2011 at 19:33:51 from (174.25.216.157):
In Reply to: Maximum Towing Capability posted by WI-Ed on September 25, 2011 at 18:22:36:
Im not a expert on the technicals of it but you will be fine with your 98 dodge. We ran a 97 3/4 ton pulling 9-10 fat cattle around. Also pulled a flatbed with 2 M's on it and a plow on the ramp.
You gotta add in the gvw of the trailer and the brakes on the trailer.
If your truck is around 8000 lbs gvw and the trailer is 14,000 lbs gvw you can have a GVW of 22,000.
Take off 6000 lbs for the truck and 2500 lbs for the trailer and you can haul 13,500 pounds of cargo. assuming your not overloading any axles or tires.
Like i said, im no expert. But i hope i helped you a little.
