Farmall A coolant overflow
Posted by Scatter on September 26, 2011 at 05:49:58 from (67.142.168.25):
Does anyone know if it"s common on an A to have a little coolant spit out the overflow line when you"re working the tractor hard? It wasn"t even enough to effect the coolant level. I just noticed my front tire below the overflow line was wet. Is the pipe plug in the middle of the block on the mag side where I would install a temperature gauge? I worked the little thing pretty hard for about 3 hours skidding some good sized logs. Made her grunt pretty hard, but the old girl got the job done. Thanks, Steve
