Safety Valve 300 Utility
Posted by truckmaster100 on September 26, 2011 at 08:09:00 from (216.68.249.194):
The power steering on my tractor is not working, the lines have a surging feeling to them when the tractor is running, if you put your hand on the hose
going to the steering unit it is pulsing, can this be from a worn out spring in the hydraulic valve, the fast hitch works fine. I just added the fast hitch and the steering worked before but not all that well, it didn't have full power even at high RPM, I am using both ports now on the side of the block, the steering block is in the back and the fast hitch is in the front, do you think it is only air in the system?
