Re: H Battery Ground Strap
Posted by BillyinStoughton on September 26, 2011 at 13:26:40 from (64.73.44.244):
In Reply to: H Battery Ground Strap posted by George Rausch on September 26, 2011 at 10:40:56:
I make my own battery cables. For 6 VDC positive ground, I use high strand #0 gauge cable that I buy from the area welding supply store. I buy the total lineal feet required to do the job and cut each cable to perfect length. Then instead of crimping the ends on I slide the cable into the terminal and heat the terminal up with a propane torch and fill it full of solder. Add 4" of heavy duty shrink tube...and now you've got a battery cable that will last your lifetime and mine...and the best part is IT FITS PERFECTLY! It's not the cheapest route, but it's the last set of cables you will buy.
