Re: H Battery Ground Strap
Posted by JRSutton on September 26, 2011 at 13:38:41 from (75.130.109.233):
In Reply to: H Battery Ground Strap posted by George Rausch on September 26, 2011 at 10:40:56:
Are you running 6 volts or 12?
If 6, then you're wise not to use it. It's probably designed for 12v.
6v requires a lot more current, and you need the heavier stuff for proper operation.
However, if you're running 12v, it'll probably fine.
I like the welding cable idea, with solder joints. I don't think you can get much better than that.
