Re: super a belt pto seal
Posted by gene bender on September 26, 2011 at 18:58:02 from (67.55.227.142):
In Reply to: super a belt pto seal posted by werowance on September 26, 2011 at 18:44:35:
The hub for the Browning pulley on the Woods has two holes drilled and tapped to screw the two capscrews in to realese the hub and it. I have removed a bunch of them will come rite off. The spacer wont stop all the lube from leaking some. Ive had the Woods mower for 40 pluss yrs on several tractors ive sold and still use one. You will get some leaks if the belt pulley gets its lube thru the tranny like its supposed to.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
