Posted by Jim Becker on September 26, 2011 at 18:59:35 from (173.57.144.251):
In Reply to: super a belt pto seal posted by werowance on September 26, 2011 at 18:44:35:
From the factory, there was a sleeve for the seal to ride on. It was much heavier than a repair sleeve. The sleeve was normally held in place by the pulley. When the pulley was removed, there was another sleeve/spacer that went on the shaft in place of the pulley to hold the sleeve.
Not sure if you need to remove the seal retainer to change the seal, but it is probably easiest if you do.
All the Woods pulleys I have removed had a tapered hub. Take the hub retaining cap screws out and screw them into the other (threaded) holes and the pulley pops right off.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
