Re: H brake seal replacement
Posted by Janicholson on September 27, 2011 at 08:44:37 from (199.17.6.160):
In Reply to: H brake seal replacement posted by WI Dave on September 27, 2011 at 07:51:00:
You can only remove the seal, not the bolted plate. Removing the plate will destroy the pinion carrier, it will not come out.
Just pry out the seal. New seals will likely be thinner. Put them in so they do not rub in the groove of the old seal. Pack the back side with chassis grease to assure it is lubed. Some times people put in two seals per side. That also works if grease is put between them. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
