The exact oil pressure is not the problem. It is a change from the normal pressure that is. A chevy six with dippers on rods had 14 psi max. An H farmall will run about 70 psi max. So, if the H only puts out 14 psi you have a problem, chevy six was fine. If you have the aluminum oil filter base I suspect the pressure relief valve is shot. Easy fix. They originally had a fiber wafer and it erodes and leaks pressure. Might be oil pump end plate if valve is good. After that, think bearings, but if it holds forty psi at higher speeds it will not cause a problem.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
