When you remove the head lay a straight edge across the head to see if it's warped. If it looks I wouldn't have it machined. A new head gasket torqued down evenly starting in the center and work out in both directions. Use 3 or 4 steps starting with 25 ft-lbs until you reach 80 ft-lbs. Set your valves at .017" cold after the engine is heated up retorque the head starting with 60 or 70 ft-lbs.
Its easy to run the front wheels along with the steering wheel out from under the engine. You may need to drain and remove the radiator to gain access to the timing gear cover. Its been a long time since I did an A. You need to support the engine well. Check the damper pulley hub for a worn groove caused by the old seal rubbing on it. They have a speedi-sleeve kit to cover that area and a new seal for the cover. Leave the bolts loose on the timing gear cover until the damper is installed. This will allow the seal to center itself. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
