Re: While we're asking what is the purpose of questions...
Posted by Bob M on September 27, 2011 at 12:47:28 from (69.207.87.100):
In Reply to: While we're asking what is the purpose of questions... posted by JRSutton on September 27, 2011 at 12:29:23:
I've got an American Bosch mag from a 40's era Waukesha power unit with a similar "window" on one side of the cap.
Directly behind the window is the rotor drive gear. One rotor gear tooth is painted white. When the mag is at TDC #1, the white tooth is centered in the window.
This feature simplifies timing the mag to the engine - no messing with the impulse coupling is required. With the engine at TDC #1 cyl firing, simply rotate the coupling backward until the white tooth appears, then mount the mag.
