The plain bearings in normal internal combustion engine do not rely on oil pressure to float the insert over the journal. They rely on a continuopus supply of oil to refresh that squeezed out. If the pressure is sufficient to get oil to the bearings, it will be fine. Exceptions are bearings and pistons cooled by the oil. The reduced flow of near no pressure can overheat journals that are subject to high temp. Jet orifices directed to piston skirts that do not supply sufficient volume far enough will cause burned pistons and siezed engines. Engines with hydraulic Lifters or other hydraulic Oil pressure related adjustment systems (including cam timing) will not be happy. Old simple tractors live with little pressure for a long long time. (not recommended) Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
