Posted by Tom Fleming on September 27, 2011 at 17:47:03 from (67.20.249.95):
In Reply to: Timing on a 46 H posted by Ofischill on September 27, 2011 at 12:34:31:
Well, that depends. I learned how to time a distributor by listening to the engine as you turn it. That doesn't make you "perfect", but it sure will get the job done if you are not looking for the absolute best setting for your engine. If good enough is good enough, run the engine up on full throttle, then with the base loose, turn the distributor one way, then the other. When you get max RPM's and a clear, full exhaust sound, you are on the money.
Otherwise, use a timing light OR..... These tractors were all designed to have the initial timing on TDC. Getting to TDC is relatively simple. with the ignition off, remove plug #1, and loosen the rest. Turn the engine over until your feel the compression stroke starting. I use a wooden dowel rod in the plug hole to "feel" the piston coming up as you slowly keep turning it over by hand. Once you have #1 at TDC, then take the cap off your distributor. rotate it until the rotor is point at approx 2 oclock (#1 plug wire on the cap.). you are now timed to TDC.
Rotating towards the engine (CCW) advances the timing. Rotation away from the engine (CW) retards the timing. If you use a starter and not the hand crank, you can advance your timing a bit, but not too much.
My advice is to time it to TDC, and let the distributor handle the advance it was designed for.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
