Re: What oil pressure is too low
Posted by F-Dean on September 28, 2011 at 05:17:08 from (75.205.196.135):
In Reply to: Re: What oil pressure is too low posted by d282 on September 27, 2011 at 09:12:19:
That is close to what I had heard, "10 PSI per 1,000 rpm." In other words, what is okay for a F-20 may not be okay for today's higher rpm tractors.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
