Re: What would you offer? Good ol H
Posted by mkirsch on September 28, 2011 at 05:56:13 from (64.80.110.74):
In Reply to: What would you offer? Good ol H posted by Eric P on September 28, 2011 at 05:23:03:
"Won't stay running" means the engine does start?
That improves the value quite a bit, but the problem could be as simple as an ignition/carburetor tuneup, or it could be major problems like valves.
See if they will let you run a compression check. If the compression is good and consistent across all four cylinders, you should be able to get it running right with some minor work.
$800 to $1200 sounds about right depending on the tires... They "hold air" but are they usable?
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
