JackinOK, You took a while to compose all that. You are right that the tractor and plow must be set up with the center of pull lined up with the center line of the plow. You can do that very easy on level ground. As soon as you go across a sidehill all those adjustments are now out of wack. The wheel slipage thing you talked about does not apply as I am talking about a 2 bottom plow with the right tire in the furrow. It's not sliding anywhere. The geometry just changes. Gravity. When you come back the other way it changes the other way. The hillside hitch was the perfect way to make on the fly adjustments so that the first bottom would take the correct size bite.
My 240 acre farm has some nice flat areas but some of it is steep. Keith
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
