B Front Oil Seal
Posted by Red Raider on August 22, 2000 at 06:20:07 from (192.105.235.146):
The B front crankshaft oil seal appears to be replaced by removing the front crankcase cover, then changing out the seal. Can you pull the cover off by only removing the crankshaft pully, governor, and radiator?
third party image
Post A Followup
: Re: B Front Oil Seal
