Re: charging system farmall m
Posted by John T on September 28, 2011 at 14:06:21 from (173.243.181.15):
In Reply to: Re: charging system farmall m posted by NORMAN MOYER on September 28, 2011 at 12:29:22:
Well, L is for lights in a way, it stands for LOADS which is lights AND ignition etc. Without the L terminal, those same loads are fed instead from the Load (NOT battery) side of the ammeter. If it had a cutout and loads were fed off the ammeter, that wire would be removed and replaced with a wire instead from LOAD on the VR up to the light or ignition switch to provide the voltage
John T
John T
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
