Posted by Janicholson on September 28, 2011 at 18:51:46 from (96.24.99.126):
In Reply to: 424 wiring diagram posted by steve in wi on September 28, 2011 at 17:49:55:
The three wire regulator bat terminal is wired to the amp meter load side with 10gauge wire. The L (4th) wire can be unused in the loom. The terminal it was hooked to at the dash (light switch probably)is connected to that same load side of the amp meter. That wire should be 10gauge also. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
