Re: farmall m cuts out when under a load- push clutch in ...
Posted by El Toro on September 29, 2011 at 04:28:57 from (108.3.225.100):
In Reply to: farmall m cuts out when under a load- push clutch in and ... posted by wallylucius on September 28, 2011 at 23:11:13:
Open the main jet adjustment screw near the bottom of the carburetor to see if this fixes the problem. Hal
