Re: farmall m cuts out when under a load- push clutch in ...
Posted by Janicholson on September 29, 2011 at 08:15:45 from (199.17.6.160):
In Reply to: farmall m cuts out when under a load- push clutch in and ... posted by wallylucius on September 28, 2011 at 23:11:13:
Take the Fuel cap off when it does it ifit perks right up the vent is plugged up. Also check the distributor shaft for bushing wear. The cam must not move more than .001" side to side (not in and out) in any direction, up down in out etc. Gap is .020"
Jim
